VAFC remove, CEL #22
Old May 25, 2003 | 05:04 AM
gilbertg's Avatar
Default VAFC remove, CEL #22
Folks,
I just removed my VAFC and now I'm getting a #22 CEL (VTEC Solenoid). Any ideas what I might have missed. I'll be checking the continuity of the wires shortly.
Old May 25, 2003 | 11:50 AM
Gernby's Avatar
Former Sponsor
Was the V-AFC hard wired, or did you have a harness? If it was hard wired, then I think the problem is obviously the VTEC solenoid wire.
Old May 25, 2003 | 01:01 PM
gilbertg's Avatar
It was hard wired. I've checked the wire and it appears to be good. Could the VAFC have masked a problem with the solenoid since it controls the signal to and from the ECU?
Old May 25, 2003 | 02:11 PM
gilbertg's Avatar
The solenoid appears to be working fine. The problem must be with the VTM signal. Since this wire is disconnected when using a VAFC there would have been no way to catch this failure. Anyone know of a way to verify that this is the case? How does this VTM signal work?
Old May 29, 2003 | 05:21 PM
gilbertg's Avatar
It turned out that the VTEC oil pressure sensor was not working. The problem had been masked by the VAFC since that wire is disconnected from the ECU. After replacing the sensor everything now works fine.
I would strongly suggest that any VAFC users that are also using a harness unplug the VAFC from time to time and verify that the sensors and solenoid are working fine.
Old May 31, 2003 | 07:42 PM
ChrisD's Avatar
Interesting information.. Thanks for sharing (even though we really had no helpful advice for you).
freshs2k
Mar 5, 2007 03:29 AM
mustangkiller01
Aug 13, 2006 06:40 AM
s2kboy03
Apr 23, 2005 08:47 AM
2broke2drive
Apr 28, 2004 08:26 PM
