vafc 2 installed and then a CEL!
Old Aug 7, 2006 | 05:59 AM
mustangkiller01's Avatar
Default vafc 2 installed and then a CEL!
after i installed the vafc 2, the car started up seemed to be good. it then started having trouble holding idle. it would come down to 900rpm for like 2 seconds and the just die. it doesn't do it every time i let off throttle, sometimes it holds fine, but other time it will just die.
this is the code i got: P1259 VTEC System Malfunction
i haven't v-tec it since i got the code about 35 mins of driving after vafc 2 installation.
is this a setting that is wrong in my vafc 2? or my mistake in wiring it?
I did reset the vafc 2 and fallowed the set up instructions by setting the cylinder # (4) V-tec type (1) and sensor type (1 in) (1 out).
I didn't mess with anything else. please help!
Old Aug 7, 2006 | 07:08 AM
NFRS2kSi's Avatar
most likely u tap the wire incorrectly..
double check ur wire.
make urself easy.. go get a bloomsang or frog harness.
Old Aug 7, 2006 | 08:31 AM
i will double check that.... is there any other possiblity?
Old Aug 7, 2006 | 11:35 AM
checking connections whe i get home...
this isn't a rough idle. it just drops out some times. would the p1259 code relate to this problem?
Old Aug 7, 2006 | 02:56 PM
NFRS2kSi's Avatar
yea. ur car won't hit vtec.
Old Aug 13, 2006 | 12:07 AM
Kenpo_S2000's Avatar
i got the code before but I hit vtec everytime no problem. What could be up with that? Could the vafc wiriing be screwed up and still hit vtec?
Old Aug 13, 2006 | 06:40 AM
all fixed. it was a bad connection. everything works perfect
Sinco06
May 26, 2007 05:18 AM
freshs2k
Mar 5, 2007 03:29 AM
s2kboy03
Apr 23, 2005 08:47 AM
redsound
Mar 31, 2004 05:58 PM
gilbertg
May 31, 2003 07:42 PM
