Vafc wiring w/ vortech box?
Old May 22, 2003 | 04:26 PM
spapdx's Avatar
I have the vafc wiring diagram for our ecu and everything looks good except for the pressure signal. The rpm, power, and ground (which the vafc and vortech box have) just splice into the ecu wiring, but the pressure signal is different. The pressure signal has to run from the sensor (in the engine bay) through both the vafc and vortech box then to the ecu. So I guess the only question that I, and I know others will and do have, is which does it go to first?? Which one of these is correct--->>
sensor - vafc - vortech - ecu
-OR-
sensor - vortech - vafc - ecu
Thanks in advance!
Old May 22, 2003 | 10:48 PM
honda9krpm's Avatar
Does the VAFC harness still work after vortech installation?
Old May 23, 2003 | 08:52 AM
spapdx's Avatar
I wouldn't know. I didn't use it.
Old May 23, 2003 | 09:42 AM
Steve@Evolution's Avatar
Second diagram is it.
Old May 23, 2003 | 10:11 AM
spapdx's Avatar
thanks
Old May 23, 2003 | 11:19 AM
Mirror's Avatar
Mine is like the 2nd diagram.
Old May 23, 2003 | 05:36 PM
DBZFAN's Avatar
Would either of you be able to post your vafc settings? Over 35% throttle she falls right on her face. The only thing extra I may have is a 72mm throttle body.
Old May 23, 2003 | 07:46 PM
honda9krpm's Avatar
Does anyone make a VAFC harness for the S with Vortech kit?
Old May 27, 2003 | 06:36 PM
VTECPHIL#6829's Avatar
My VAFC harness works perfectly w/ the Vortech control box. I got it through cyberlogic. 2nd diagram is right as you want the VAFC "downstream" from the other connections. My car runs much smoother and has a better "sound" than before the dyno/VAFC tune. I am having a ton of fun with the S/C!!! Phil
kstokell
Apr 5, 2004 03:17 PM
Modified S2k
Mar 12, 2004 02:16 PM
NiN
Dec 7, 2003 11:44 PM
itsallforyou
May 12, 2003 08:33 PM
S2Million
Jan 12, 2003 08:55 PM
