Vortech SC with Apexi Black V-AFC
Can someone point me to a link to help wiring and installation of a VAFC. I already have a Vortech installed on a stock 2003 S2000.
Do you wire the VAFC before or after the Vortech timing controller?
Originally posted by honda9krpm
the small vortech box, before the vafc and ecu
I still don't get it. I'm not arguing with you on this, I really want to know how you are doing it.
If you Voltage Clamp is upstream of the VAFC, are any of the VAFC settings above, say 3500, +ve? The reason I ask is that the Voltage Clamp is pinning your MAP signal to 2.9V so the ECU doesn't retard dramatically. But if that 2.9 V is going into the VAFC, and the VAFC is upping it (attempting to add fuel), then your ECU is seeing boost and retarding?
Of course if none of the settings above 3000 are positive then I guess it makes sense, but otherwise I am very confused.
kstokell
Apr 5, 2004 03:17 PM
