Valve adjustment?
Old Aug 11, 2006 | 02:56 AM
RACER's Avatar
I have one of these.
Old Aug 11, 2006 | 03:00 AM
CoralDoc's Avatar
So do I, but mine is bigger.
Old Aug 11, 2006 | 11:24 AM
Squeezer's Avatar
where did you buy that?
Old Aug 11, 2006 | 11:27 AM
iDomN8U's Avatar
10,000 miles for a value adjustment, are you sure about that??
Old Aug 11, 2006 | 11:33 AM
centralcoastbuc's Avatar
Originally Posted by iam7head,Aug 10 2006, 01:41 AM
i just did it for my S, almost 95K, not sure the previous owner did it before this tho'
i actually did it twice in two days, the first try was too loose, it was ticking like a car bomb.
the first thing I did it took me 4 1/2 hours, the second time was 3 hours.
it sucks because you have no room to put your body/hands on without denting fenders. i did valve adjustment for my other honda, so it;s like my fifth time doing that.
batter heat shield need to come off, the spark plug coil wires need to be loosen, the injector cover needs to be off, pcv, sparkplug, cover, strut bar if you have one of those, two more sensor on the side of the VC, etc
just abunch of little things is in the way, oh, when i almost have to tighten up all the valve at 95-100K so if you could spend some time, do it at 75k
The only reason I have a shock tower bar is for something to lean on when I am working on the engine.
I just put blue tape over the edges of the heat shield so I don't cut my arms and work around it.
Old Aug 11, 2006 | 11:49 AM
NFRS2kSi's Avatar
it's useless for s2k.
just use regular wrench and screw driver.
that tool is good for b-series head.
Old Aug 11, 2006 | 12:24 PM
Not true. I use that Exact tool for the S2k. It works fine.
Old Aug 11, 2006 | 12:29 PM
NFRS2kSi's Avatar
what i meant was that "yes" it's useful, but not enough to buy extra tools to do vavle adjustment.
Old Aug 11, 2006 | 12:59 PM
RACER's Avatar
here ya go
Old Aug 11, 2006 | 06:53 PM
Squeezer's Avatar
Originally Posted by RACER,Aug 11 2006, 02:59 PM
thanks
