Valve Adjustment
Old Sep 29, 2006 | 07:11 AM
SWFLS2K's Avatar
Default Valve Adjustment
$147 includes the valve adjustment and a synthetic oil change from Todd @ 2nrwerks. I have owned a Celica GTS w/ 50000 miles and a Toyota Matrix XRS w/ 39000 miles and those 2ZZ-JE engines are designed somewhat similar to a Vtech engine and I never heard about valve adjustment. What exactly is the process and is it really necessary? I have an 03 w/ 42000 miles. Thanks in advance.
Old Sep 29, 2006 | 07:36 AM
snakeeater's Avatar
If you hear the valvetrain ticking, it's because the clearances aren't right. Very serious issue when clearances are wrong. $$$$ damage usually follows. The manual says to have them checked at certain intervals.
Old Sep 29, 2006 | 07:40 AM
SWFLS2K's Avatar
There is a very little audible clicking sound. I am going to wait unitl 45000 to do the adjustment and a synthetic oil change.
BTW, what is involoved?
Old Sep 29, 2006 | 08:06 AM
SilverDC2 AP1's Avatar
they take off your valve cover, and adjust your valve, they adjust them if their too loose or too tight, thats about it.
Old Sep 29, 2006 | 08:20 AM
xviper's Avatar
Here's a complete "How To" ....................
https://www.s2ki.com/forums/index.php?showtopic=245555
Not quite. You will always hear a bit of valvetrain noise. That's just the nature of the beast. The trick is to know when it's not normal. If you DON'T hear anything, that's when you need to worry a bit more than if you hear too much. If you don't hear anything, that means the valve lash is too tight and the valve is being pushed down into the cylinger too far (and we all know what can happen then). My 00/01 manual states to do a valve adjustment "only when noisy" or at 7 years/105K miles.
Valves tend to get noisier with use as wear continues. They won't get quieter unless something really weird has happened.
Old Sep 29, 2006 | 11:32 AM
SWFLS2K's Avatar
Well I guess if someone is driving 2.5 hours to have his S worked on by 2nrwerks then someone must know a thing or two. Thanks for the replies.
Old Oct 6, 2006 | 09:11 AM
530s2k's Avatar
Dude. VTEC.
Everyone all at once. V T E C.
Once more! V-T-E-C
I sure as hell wouldn't have bought this car if VTECH had contributed in any way, shape, or form.
Old Oct 6, 2006 | 02:34 PM
kiowa132001's Avatar
It is good to have you're valves adjusted every 30,000. I do mine at that interval. I have seen check engine lights with multiple missfire codes and it is due to having the valve lash out of spec. Basically I keep mine adjusted so I don't need to worry about MIL.
Old Oct 6, 2006 | 08:13 PM
REVZ TO9's Avatar
Banned
yah every 30K, have one done. Also, its best to have your valves more on the loose side than tight side. But still they should be done correctly.
jWESTFOO
Jun 1, 2014 04:53 PM
Nametaek3n
May 7, 2013 11:57 AM
JakeAP1
Apr 21, 2010 10:53 AM
RydinRuff
27
Dec 6, 2008 11:29 AM
jyeung528
Jan 29, 2007 01:36 PM
