Valve Adjustment Experience
by checking the gap. either by a professional or as per Destiny2002
https://www.s2ki.com/forums/showthread.php?...&threadid=93197
you might not need to adjust anything. the only true way to tell is by checking the gap. unless you have bigger problems.
Originally posted by DJSang
so how would I know for sure that I need a valve adjustment, other than just engine noise??
BTW, don't critique the valve's clatter when the car is cold... only after it's warmed up.
cool cool, thanks guys...
When cold, the motor even kind of shakes, it never did that before, I think it's time to take it in to the dealer for valve work...
Many cars were mal-adjusted from the factory. If not, you will likely see little change in the adjustment and even more likely little improvement by adjusting them.
If you want to see a "difference," tighten the clearance by .002." The increase in lift and duration is noticeable, and the characteristic Honda "tick" is quieted significantly.
Originally posted by KYS2000
Hey Gernby could you post the specs on what the intake and exhaust should be?
Marcucci, did you put your step-by-step valve adjustment guide on on the web?
