Valve clatter on startup for about 1 sec- Problem?
Hi everyone,
I have a 2001 S2000 (I've had since new), with 105K miles, and it has what I think is a new problem I noticed recently.
On startup, it often (maybe 2 out of 10 startups) makes a valve-clatter noise for about 1 second. (FWIW I use mobil 1 10w30 and it's hot here in new england lately).
I want to understand what the problem is, and if there is some kind of fix for it, what is it? Can aftermarket products help? (ie, slick-50 or other product)
Also, should I worry about it?
I just got a new top for the car, and it's basically like new, so I don't want to be doing any damage to the engine.
Thanks for any help!
Steve
Steve
Originally Posted by AusS2000,Jun 10 2008, 05:10 PM
I expect it is the timing chain rattling until the tensioner gets oil pressure. Fairly common. Solution is to replace the timing chain tensioner.
Steve
Originally Posted by AusS2000,Jun 10 2008, 05:23 PM
Not sure what damage can occur but it is little work to remedy it.
I had major service done just 15000 miles ago, and wonder if they did this then.
Hmm....
Steve
If the timing chain autotensioner is bad and gets worse to the point it allows your timing chain to jump time there will be damage......expensive damage. You should fix it now before it gets worse...
Simple fix...do a search..there is a how-to in here somewhere...
The part is just a little over $100 last I checked. 10 minute job if you take your time.
Originally Posted by ronnuke,Jun 10 2008, 05:43 PM
Found it.... page 2
https://www.s2ki.com/forums/index.ph...c=320897&st=25
I'm almost positive that the valve tensioner is it.
This is great - I feel better now knowing that 1) I'm not the only one with this, and 2) it's an easy fix!
Thanks everyone!
Steve
ledhed
Apr 30, 2012 08:36 PM
