Valve Cover Bolt
Old Jul 10, 2015 | 10:41 PM
Beho88's Avatar
Default Valve Cover Bolt
Sooo...one of my valve cover bolt broke off (on the grommet). Its the far end on the driver side towards the radiator. Is it okay to drive around like this or can I just match the bolt to another one at a hard ware store as a temporary fix? The nearest Honda is a special order for those bolts with a 5 day wait..
Old Jul 11, 2015 | 02:26 AM
xxmass's Avatar
Home Depot does have a large variety of bolts. I think it is well worth the effort to remove a good one and try to match it to one there.
The part number for those bolts 90013-PCX-000 is used on other engines. Maybe a visit to the junkyard could get you one.
Old Jul 11, 2015 | 04:57 AM
Chuck S's Avatar
This product fits 445 vehicle variants.
Honda: 7 models, 445 variants between 2000 and 2015.
I can't believe this is "special order" with all the Honda dealers around.
The bolt is listed as "6x12" whatever that means.
-- Chuck
Old Jul 11, 2015 | 05:03 AM
S2Ko0o's Avatar
I just got some grade 8 ones that matched the thread at the local parts store, local honda didn't have any and couldn't give me a timeline to order. I replaced all of mine since they get heated and cooled a lot so they become brittle it seems.
Old Jul 11, 2015 | 07:02 AM
Chuck S's Avatar
These bolts should not be breaking. They sit on top of thick rubber grommets and are only torqued to 8.7 lb-ft.
But at a buck and a half each I'd buy a set of 5 and torque them properly. Keep the 4 old bolts as spares.
-- Chuck
Old Jul 11, 2015 | 09:09 AM
Beho88's Avatar
Thank you all!
Old Jul 11, 2015 | 09:26 AM
gptoyz's Avatar
The bolt is under such low pressure that you can back it out by using a pick or screwdriver or magnet and some patience
There's only 5 of those bolts plus the coil pack bolts which put pressure on the valve cover to ensure a good seal without oil leakage
But any bolt that is the correct thread pitch will be fine
Old Jul 11, 2015 | 02:08 PM
Slowcrash_101's Avatar
5 x 8.7 ~ 43.5 So the VC is clamped down with ~ 43.5 ft lbs from the cover bolts. The clamping force between two mating surfaces is the sum of all fastener tension on that surface, that is partly why there's a specific tightening sequence. Remember torque does not equal tension, tension equals tension. Torque on a bolt corresponds to tension, torque causes less tension when there is more friction between the fastener and the surface. For example, when doing the head, you have to oil the threads and the top of the bolt, and the manual explicitly states that if you hear any noise while installing the bolt to stop back off and try again, because bolt tension is so critical. Also why fresh head bolts are tightened in 3 90 degree steps, as opposed to re-used bolts which are tightened in two 90 degree steps. Also why the manual recommends an analog tq wrench, and if using a click type to work very slowly. This is partly because you can actually feel the fastener stretch and clamp if you work slowly, and mostly because creating the correct tension on head bolts is critical to proper engine function.
Valkyrie
Oct 13, 2014 12:19 PM
Mallain123
Jun 19, 2013 08:15 AM
john82389
Jun 18, 2012 11:22 AM
mnr12
May 22, 2010 06:57 AM
Squeezer
Feb 21, 2003 08:35 AM
