Broken bolt
Old May 21, 2010 | 01:49 PM
mnr12's Avatar
Default Broken bolt
My buddy over torqued one of the bolts on my valve cover and snapped the top off. What are some ways i can get the rest of it out.
I've heard of the screw you drill in and drill back out but I don't think it'll work due to the size?
Old May 21, 2010 | 03:43 PM
downloader's Avatar
take the valve cover off, and see if there is enough left to get a vise grip on it
Old May 21, 2010 | 04:20 PM
jeggy's Avatar
valve cover bolts screw into the tops of the cam tower bolts. worse case, you just remove the cam tower bolt (12mm) that has the valve cover bolt broken in it and replace it.
Old May 21, 2010 | 04:40 PM
Alphamale's Avatar
I did this. There was enough of a lip left I was able to loosen with a screwdirver and then back out by pressing down with my finger tip and turning. If you can back out just a little these are removable by hand. They do make a small enough Easy-Out though.
http://www.grainger.com/Grainger/items/1U216
Old May 21, 2010 | 06:16 PM
munkieejiism's Avatar
I've had that problem too before with the valve cover bolt and cam cap bolts. POS tourqe wrench. Check to see if you can get a grip on it, if not...get a reverse drill bit. You can get it from kragen and such. Drill a hole big enough into the bolt to have a good bite on the reverse drill bit. Screw the drill bit by hand into the broken bolt hole you just drilled. Then get a plier and turn the reverse drill bit slowly. It'll come out, just make sure to have a good bite on the bit and broken bolt.
Old May 22, 2010 | 12:38 AM
bradskee's Avatar
i had this happen last week. Because the head broke off its not in there tight at all. Use a reverse but (like a grabit) and it will spin out real easy
Old May 22, 2010 | 01:07 AM
toniotran's Avatar
and make sure to use a center punch to make an indent directly in the center of the broken bolt to give the bolt extractor more surface area to grab.
Old May 22, 2010 | 06:57 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If it broke while tightening, torque has been released. You could very well just spin it out with your fingers, needle nose pliers, or sharp pick.
EF9 Sedan
Apr 9, 2015 10:33 PM
Mallain123
Jun 19, 2013 08:15 AM
john82389
Jun 18, 2012 11:22 AM
chudc
May 18, 2004 05:25 AM
Squeezer
Feb 21, 2003 08:35 AM
