valve not fit in new valve guide
Old Dec 1, 2014 | 05:26 PM
ek206's Avatar
Default valve not fit in new valve guide
Hello s2ki
I bought new valve guides to replace with worn guides. But the new valve guides are too small for the valves. It doesn fit at all. Anyone had same expirience? Thanks.
Old Dec 1, 2014 | 06:09 PM
postman's Avatar
Have they already been installed in the head? What type of guides are they?
Old Dec 1, 2014 | 06:16 PM
ek206's Avatar
Not installed yet. Just tried to put the valve into the guide but it doens fit. And those are oem honda parts.
Old Dec 1, 2014 | 06:36 PM
windhund116's Avatar
Dimensions of the valve shaft and the guides maybe different between intake and exhaust.
Old Dec 2, 2014 | 05:53 AM
MM3Kwolik's Avatar
Guides are side dependent (intake are different from exhaust), but also, new guides usually get reamed out to fit after installation as installation can sometimes cause burring on the ends of the guides.
Old Dec 3, 2014 | 04:47 AM
ek206's Avatar
Thanks Jordan
So you are saying that i need some burring work on the ends of the guides after installing them?
Old Dec 3, 2014 | 05:01 PM
Slowcrash_101's Avatar
Don't you have to heat the head and freeze the guides to install them?
Old Dec 4, 2014 | 03:05 AM
MM3Kwolik's Avatar
Yes Slowcrash. The guides get frozen and head heated to aide in the installation, but even still, a guide reamer is generally used to achieve the final sizing.
Old Dec 4, 2014 | 05:57 AM
Bliss's Avatar
Use dry ice -109 ° shouldn't have to heat head.
This is the way I would sleeve a block as well.
Be sure to have container for dry ice vented. Or boom.
Old Dec 5, 2014 | 05:56 AM
wadzii's Avatar
Banned
Unless your guides are TRASH I wouldn't change them, most shops will screw it up more than anything. New guides will have to be reamed after they are installed.
Honda drills the guides after they are installed so the actual guide hole may not be exactly inline with where the valve needs to be. So when you replace them 75% of the time you end up having to sink the valve job to get the valve to seal up properly. Sinking the valve job kills flow.
Belkin623
Nov 3, 2015 12:17 AM
s2konroids
Jan 26, 2011 01:18 PM
Armend17
May 22, 2010 10:31 AM
duanet85
Aug 30, 2008 09:06 PM
