valves too tight?
Old Sep 22, 2008 | 09:15 PM
Mrblu's Avatar
Default valves too tight?
I have a 10% leak on both intake and exhaust after a leak down test on cylinder one. I have a compression of 90 then it went down. I did a valve adjustment a few months before this happen, is it because the valves are too tight?
or do i need to do a rebuild, or replace the valves only.
Old Sep 23, 2008 | 01:25 AM
mgraham17's Avatar
I think this was in another thread but again: check your valve clearances at TDC compression stroke for that cylinder. no clearance = bad. once they are correct, do a leakdown test with the motor at TDC compression stroke (once again) for that cylinder. listen out the intake, exhaust, and oil cap/case breather to tell you what your problem is.
EddieNewYork
Jun 25, 2017 09:41 AM
westfield147
Jun 15, 2012 09:53 AM
Brandonrawr
Feb 24, 2012 10:24 PM
durtysocks
May 29, 2011 12:49 PM
drhess06259
Jun 9, 2010 05:36 PM
