Various issues
Old Apr 26, 2016 | 07:36 AM
Spiny Norman's Avatar
Default Various issues
My 2001 is on 263,000 miles
It's the best car I ever owned, my daily driver since 2003 and I've a blast. Recently it's had low speed hesitation, started to misfire with multiple cel misfire codes. I replaced the plugs and air filter and it runs beautifully again but still has the misfire cel.
On Friday night I pressed the clutch, there was a loud clunk and it felt like something snapped, and the clutch pedal hit the floor. I got it towed to my regular shop, where we looked at the slave cylinder and master cylinder an both seemed fine. The clutch is really stiff and I can't start the engine. There's just a clicking sound which sounds like the starter is trying to engage but doesn't. A new battery didn't make any difference and I'm thinking the starter needs replacing but it seems weird the starter would go out at the same time as I have the clutch issue.
Does anyone have any advice for me? As I said it's a 2001 with mega miles, runs beautifully and I'd like to keep it but it's probably not worth too much and in addition I had plans for a new roof and windshield. Any thoughts on what the issues may be? Should I invest the money or am I looking fer a new car though I can't imagine life without an S2000
Old Apr 26, 2016 | 09:31 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You broke the clutch fork pivot. It is held on by two bolts.
If you are slick, I believe you can replace it in minutes without pulling the transmission.
Old Apr 26, 2016 | 10:30 AM
Thanks Billman250. That would make my day I just got a quote for $1460 replacing the clutch, so I'm hoping you're correct
Old Apr 26, 2016 | 01:53 PM
Billman250 - we had a look at the fork and you're right, it's broken, but how do you get it out of there without dropping the transmission?
Old Apr 26, 2016 | 05:28 PM
Billman250's Avatar
Top Answer: 1
I am not 100% sure it can be done, but it might. Get in there with a 12mm swivel and a bright light.
Old Apr 26, 2016 | 07:10 PM
S2000 Cabrio's Avatar
On a very high mileage car, it could be your injectors or the coil packs for your misfires. maybe they are all worn out and need to be replace.
Old May 5, 2016 | 06:19 PM
thanks
Old May 5, 2016 | 06:34 PM
Backmarker's Avatar
Could an engine with that high mileage just not have the compression anymore, and is missing due to failing piston rings? I'm no expert, I'm kind of just piggy backing on your questions to ask some more. Hehe
Old May 5, 2016 | 07:27 PM
AP1Driver's Avatar
Slalom44 has over 350k on his original engine and no issues. All depends on maintenance and proper treatment...
Old May 5, 2016 | 07:46 PM
Backmarker's Avatar
Daaaannnggg! Thats good to hear!
