VErsion 2 Toda cams
Old Jul 28, 2003 | 10:26 AM
  #221
beroznikmal's Avatar
Wicky,
I think the numbers recommended are .026 EX and .23 intake.....
Beroz
Old Jul 28, 2003 | 10:32 AM
  #222
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by TedS2K
[B]Are you running TODA cams? not the best idea to run different valve clearance than what TODA recommends. Could damage your cams.
Old Jul 28, 2003 | 10:34 AM
  #223
true that
Old Jul 28, 2003 | 10:42 AM
  #224
wicky's Avatar
I am running toda cams. I highly doubt anything will be damaged. There would be a lot of cars running around with damaged cams if a difference of .002" was going to "damage" anything. It will however seriously effect perfomance. I am quite happy with how the cams feel right now. The top end breaths fantasticly. I took it to 9k and it would not stop turning.
Beroz - you are correct on the recommended clearances for the Toda's. I find it interesting that those clearences are pretty stock (.021-.026 in, .025 - .029 ex)
the clearances before adjust were about .028 both sides. didn't break anything.
for what its worth, having smaller clearences will enable the valve to be open longer, and will reduce the force of impact from the rocker. Having the valves open that tiny amount more help the head to breath more, hence better top end power.......
Old Jul 28, 2003 | 10:48 AM
  #225
yes...I wish we had a dyno you our disposal..... Play with the clearances and see which # is the best.....
Good luck my friend. Its the 2nd for me......it was nascar for me yesturday.. I am bearly recovering right now..............
  #226
Gernby's Avatar
Former Sponsor
I run slightly less than spec valve clearances myself, but I am using the stock cams. Running less clearance reduces the amount of time that the valves are fully seated, which increases their temperature and increases the chances of burning a valve.
Old Jul 28, 2003 | 10:52 AM
  #227
wicky's Avatar
true. there is always risk in making power I suppose..... You can always rebuild
Old Jul 31, 2003 | 02:54 PM
  #228
S2000_Europe's Avatar
[QUOTE]Originally posted by beroznikmal
[B]Also,I am still trying to decide if the Spoon values are worth it.
Old Jul 31, 2003 | 02:56 PM
  #229
wicky's Avatar
good for a higher revving motor as long as the springs and retainers can handle higher revs. You may be able to squeeze more power out. Revving the engine even higher probable won't help it last much longer though.....
Old Jul 31, 2003 | 03:02 PM
  #230
[QUOTE]Originally posted by wicky
[B]good for a higher revving motor as long as the springs and retainers can handle higher revs.
