VErsion 2 Toda cams
Yeah I also have the second gen cams and I herd the same thing after Jack from www.p1auto.com had called up the guys at toda and gave him new settings we would of had no idea unless if it were beroz thanks ~nate
***also the setting should take care of the loss in power high end**
Nate, no problem......
Yes...the valve are being adjusted and will have the dyno results tomorrow......
gernby, I do not know what the clearance is..... I will fine out tomorrow when I get the car back......
Sorry.....
I promise to update....
Beroz
Sorry.....
Beroz
In addition, the Toda guys said they had included this info in the package...but obviously not...unless it was invisible paper.......
Maybe Toda deliberately didn't include it to eliminate the grey market.............so they can say see we told you you needed tech support.......
evo s2000 make sure you get this info to customers before they install the cams.....
Beroz
Beroz
Beroz
Beroz
when they get here, I'm thinking the end of june. I'm also considering the EMS instead of piggy back..... I'm getting nervous having the stock ecu in the mix. I don't want it compensating for what I'm compensating for. I don't like that approach.
