Vibration at speed?
Originally Posted by BroInTheKnow,May 5 2005, 10:05 PM
U sure about that? How does a drive shaft stay straight when it moves forward and over bumps???
Vibration at high speeds could result in bad CV joints
U sure about that?
As for the squeak from the right front,mine did the same thing. Found it to be coming from the lower spring seat/rubber pad/lower spring coil area. I sprayed it with white lithium grease....never to return..
I don't know if you have the same culprit,but good-luck
Originally Posted by 9kI4,May 5 2005, 07:05 PM
Any other help?
I've just bought a 03 with 33k miles on it, mine does it same thing. I got it balanced today and it's alot better now but still there @ 72 mph. The tires are brand new too. =(
What was the cause?
