VSA/Triangle Light - Steering Wheel Angle Sensor
Old Oct 22, 2014 | 04:08 PM
maranelloboy05's Avatar
Default VSA/Triangle Light - Steering Wheel Angle Sensor
Hi all,
Had an EP3 wheel on my car and swapped back to my OEM steering wheel and suddenly I have this VSA and Triangle light on. All I did was pull off the wheel and put the new one on, battery disconnected while I did it. Had my friend run the codes with his Honda tool and came back with a number of faults including the failure of the steering wheel angle sensor. Not sure how I could have broken it, but does this sound correct? Wanted to get another opinion before I spend $200 on a new sensor.
Old Oct 22, 2014 | 04:38 PM
apage's Avatar
Chances are when you replaced the steering wheel, you moved the steering wheel angle sensor (which is behind the ABS clock spring). If the steering wheel angle sensor is off by a small amount (~5 degrees), it will throw the code you described. You can read and reset the angle sensor using a Honda HDS. I would try that before you replace the sensor. Unless you were rough with the steering wheel swap, that sensor should be fine.
Old Oct 22, 2014 | 04:44 PM
Do I need to remove everything again and try and straighten the sensor?
Old Oct 22, 2014 | 04:48 PM
apage's Avatar
Nope. Just reset it with the HDS tool.
Old Oct 22, 2014 | 04:49 PM
Tried it and it didn't reset.
Old Oct 22, 2014 | 04:51 PM
apage's Avatar
What angle is it reading? Just to be clear, when I say "reset it", I mean tare (re-calibrate) the angle sensor to 0 degrees and then clear the codes.
Old Oct 23, 2014 | 04:58 PM
Gottabfast's Avatar
It won't reset if it's too far off. Also, if you were too far off and went lock to lock you may have broken it
Old Oct 25, 2014 | 11:36 AM
Didn't go anywhere near lock to lock, but regardless it wont reset and I just ordered the sensor,
Monacos2k
Apr 5, 2014 11:20 AM
chr15t0s
Jan 10, 2014 09:37 AM
verik07
28
Nov 11, 2011 02:05 PM
Survey S2000
Feb 5, 2009 12:04 PM
