VTEC and Cooling Issues
Old Feb 25, 2022 | 08:40 AM
Tony117's Avatar
Default VTEC and Cooling Issues
Hopefully you guys can help me on this one, so this is currently where I stand with my car. I replaced the thermostat with a mishimoto one (Due to overheating, thought id start there) , thinking it would help keep temp down. I replaced it all and did a flush/bleed leaving me with heat coming into the cabin, but now my temp gauge is only reading 1-2 Blocks on the cluster and fluctuation between the two. ( Not sure if that's just the Mishimoto thermo doing its job the way its intended?) But the kicker here is my VTEC is now not working, doesn't kick on even after high load, also it seems to redline at 7k RPM, acting as if i hit 9K...? ( I checked the oil and everything seems to be fine, i topped it off just to be sure but no change.) I also now idle at 1300 RPM regardless of how long I warm it up and or drive the car.
Please help my dumb a$$, this ones been tricky.
Old Feb 25, 2022 | 08:43 AM
Chuck S's Avatar
Why did you post this twice? It's already part of an earlier post. All this does is fragment your responses. See mine in the original post.
Old Feb 25, 2022 | 08:51 AM
Tony117's Avatar
Was trying to delete last forum (Not sure how) and place it here instead, thought I had posted in the wrong place, "Under the hood" seemed more reasonable!
Crobin_1
Mar 22, 2014 08:21 PM
AbbsZ
Feb 6, 2013 04:30 PM
HondaS
Jul 13, 2008 03:38 PM
thrackley
Oct 20, 2002 07:29 PM
BlueS2000Boy
Jun 17, 2002 09:47 AM
