vtec cutting in-out over 6000
Old Mar 31, 2008 | 01:54 PM
s2k aok's Avatar
nice tip, ten cent mod...
Old Apr 2, 2008 | 04:41 AM
kohl-smith's Avatar
The car has 74,000 KM's on it. I'll check out the tie wrap as well. I'm not big on the tuning thing but whats whacking the map?
Old Apr 2, 2008 | 05:36 AM
icemans2k02's Avatar
i had the same issue with mine, turned out my ecu had loosened up on the floor panel and it was badly grounded.
Old Apr 2, 2008 | 10:18 AM
nfrs2k's Avatar
Had this happen to me. I didn't even have to use the zip tie although it is a much better idea. I just unlugged it gave it a "whack" and reset the ecu.
Map Whack how to
Old Apr 4, 2008 | 05:11 AM
kohl-smith's Avatar
Sweet unfortunately this is what i wanted to hear... someone that has had the same problem more than likely i've got the same thing. Trying the zip tie this weekend. If not i'll check out this floor panel connection. Will report back in a couple days.
Old Apr 4, 2008 | 05:34 AM
S2KVITO's Avatar
Do the "map wack" zip tie it and pull backup fuse on your fuse panel rest the ecu and your car should run fine afterwards.
Old May 17, 2008 | 02:26 AM
kohl-smith's Avatar
Hey guys haven't posted for a while been overseas did what you said there "s2kvito" and the car is running fine, I've got the power back when i want it. Thanks for your time.
albe
Mar 29, 2008 11:10 AM
S2ky0118
Oct 11, 2006 05:39 PM
Freakaccident
Sep 12, 2002 09:25 PM
stockport_lad
Apr 15, 2002 12:32 PM
FSures
Mar 31, 2002 04:49 PM
