Vtec engagement problem
Old Aug 9, 2011 | 08:00 AM
funat9000rpm's Avatar
Default Vtec engagement problem
I'm having the following problem under "spirited" acceleration: In first gear, with the engine at preferable operating temperature, vtec will engage at approximately 6,300 rpm instead of the usual 6,000. In second and third gear, Vtec engages at about 6,200 rpm and then disengages briefly and engages again at about 7,000 rpm.... Since Vtec is oil pressure related, could it be that the oil level is too low? (Checked, and it is "somewhat" low, will replace oil today) Or could it be that the Vtec solenoid needs to be cleaned? Please advise
Old Aug 9, 2011 | 12:49 PM
S2k_fever's Avatar
I would check the solenoid and see if it needs to be cleaned
Old Aug 9, 2011 | 01:02 PM
s2cho's Avatar
i noticed that if the oil isnt spot on with the level vtec wont kick as hard or it ill hesitate.
Always check at every fill up and top off untill around the three X's on the dip stick.
Old Aug 9, 2011 | 01:54 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It would be a very rare case if the VTEC valve needed cleaning.
Old Aug 9, 2011 | 04:03 PM
I checked, and it was the oil level, thanks man!
When I bought the oil filter at Honda today, the salesman said that the ECU would throw a CEL for the solenoid and that it would in fact be really rare...
Old Aug 10, 2011 | 06:54 AM
Saki GT's Avatar
I'm surprised checking the oil level wasn't the first thing you did.
Old Aug 10, 2011 | 12:04 PM
it was it's just the thing that with 5W-30 I had hesitation problems past 6k, now that I switched to 10W-30 full synthetic it pulls nice and strong
brunodkid99
Jun 9, 2007 07:03 AM
Detroit
Jul 10, 2005 08:57 PM
StinkyTofu
Jun 4, 2005 09:37 PM
angrybee
Jun 21, 2002 05:00 PM
stockport_lad
Apr 15, 2002 12:32 PM
