Vtec locking pins interchangable?
Old Oct 23, 2012 | 02:38 PM
overrev_it's Avatar
Default Vtec locking pins interchangable?
Hello,
i want to ask is the vtec locking pins for the F20 interchangable with other vtec engines from other series(K-Series etc)?
it would be the small pin that engages vtec, are they the same?
i can't locate one easily for the F-Series
thanks
Old Oct 23, 2012 | 07:31 PM
The N/A Way's Avatar
Im in the same boat need to find a set (one long and one short)as well.
Old Oct 24, 2012 | 02:57 PM
overrev_it's Avatar
if anyone can help with measuring the F-Series pins diameter and depth that would be helpful and (if possible) specify thr material of the pins
it will help when comparing between other locking pins to determane if possible to swap
thanks guys
oh and The Na Way will you keep in contact if you had any information that would be appreciated and i will do the same
Old Oct 25, 2012 | 01:48 AM
I used a cheap caliper but these are what I got.
Short Pin: diameter 8.99mm length 14.77mm (Solid)
Long Pin: diameter 8.99mm Length 24.49mm (hollow)
Very hard metal looks pretty scratch and dent resistant but not sure what it is.
Old Oct 25, 2012 | 02:44 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have a civic guy around the corner with boxes of parts from many different civic engines. If the parts match, I can send you guys some pins.
I'll post measurements as well.
Old Oct 29, 2012 | 03:49 PM
Buzz2K's Avatar
any update from Billman?
Old Oct 29, 2012 | 08:37 PM
Buzz2K what pins do you need?
Old Oct 30, 2012 | 01:38 PM
chris_barry's Avatar
I've compared the F20 and K20 pins and they are different lengths. I've used the F pins in a K motor to lock the rockers into the VTEC position while dialling in the cam phasing.
antonis S chania
Κινητήρας - Μετάδοση - Περιφερειακά
May 28, 2010 03:28 AM
jo.strup
16
Apr 2, 2010 10:34 AM
Catahoula01
May 18, 2007 10:43 AM
jrwst39
Jul 15, 2003 06:56 PM
