Vtec Problem?
Old Dec 10, 2006 | 03:44 PM
Nametaek3n's Avatar
Default Vtec Problem?
I bought my car used from the original owner with 13k miles on it, about 2 years ago, i just recently hit 33k miles. It's an 00'. i don't know if my Vtec is kicking in as hard as it should or if I'm just used to the car now. I changed my spark plugs this weekend, looked as if the car is running a little lean, the electrode was worn down. and the tip was somewhat whitish. I actually have two questions, the first is the motor starting to loose its umph! or am i just getting used to the car. my time for some mods. And the second question is if the car is running lean, how do i correct it, can i adjust the fuel pressure on the stock regulator or do i need to do something else. sorry for having a run on thread, just worried bout my baby. although it maybe nothing.
Old Dec 10, 2006 | 04:09 PM
milkbubble's Avatar
I read about this somewhere.. From what I recall you should check your airfilter and replace if it is worn and then reset the ECU. Try to search it out I seen this happen more then once.
EDIT:
Read this thread I found for you below:
https://www.s2ki.com/forums/index.php?showt...0&#entry9122526
CHAD
Old Dec 10, 2006 | 04:52 PM
Nametaek3n's Avatar
Thanks Chad, I'll give that a try and see if that fixes the problem.
Tom
Old Dec 11, 2006 | 08:33 AM
vtec9's Avatar
Well, maybe a stupid suggestion, but often overlooked nonetheless.. have you checked your oil level?
Jonesybubs
Jul 27, 2012 05:59 AM
801AP1
Oct 17, 2011 04:57 PM
TPhong
Sep 6, 2009 08:14 PM
bioman
Jan 5, 2009 10:02 AM
JaxShawn
Feb 11, 2007 01:31 PM
