VTEC solenoid valve assembly damage Halp!
Old Jun 19, 2012 | 11:17 AM
MikeBuff's Avatar
Default VTEC solenoid valve assembly damage Halp!
Hey all,
Was doing my swap and the chain from the hoist ripped the plug on the solenoid, see attached images:
Looking for some help on how to fix this (very new to honda)any input would be appreciated.
Old Jun 19, 2012 | 02:02 PM
Nutterbutter's Avatar
You can buy a new sensor from the dealer. Its around $50.
Old Jun 19, 2012 | 03:15 PM
MikeBuff's Avatar
Thanks what about the wire harness, the clip is smashed am I going to need another whole harness bc of that ?
Old Jun 19, 2012 | 08:38 PM
TonysMI4's Avatar
Pm me.... I can cut you off part of my extra wire harness , then you can just cut and rewire it back in. I also have and extra sensor. Shoot me a price. FYI you would have to buy a whole new wire harness
Old Jun 20, 2012 | 04:59 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you get a new connector end used for your harness, you can do it without cutting as long as the female pins are good.
Use an eyeglass screwdriver to extract the pins, and plug them into the new connector. This way you have a factory perfect repair with no cutting.
jrbean
Jun 22, 2014 03:07 PM
S2kbryan
May 4, 2014 09:25 AM
AZ-S2000
Mar 23, 2013 05:13 AM
turbo8765
Nov 12, 2011 08:55 AM
addisonc
Jan 30, 2007 10:47 AM
