VTEC Stutter ?
Old Aug 23, 2004 | 09:14 AM
BeachBum's Avatar
Default VTEC Stutter ?
Has anyone experienced the feeling that the power in VTEC is not comming one smoothly?
At the track last weekend and even powering onto the highway, in noticed that in 2nd and 3rd, the engine doesnt power smoothly from 6k to 9k.
It almost feels like the engine is having trouble getting gas. Although, there should have been plenty of fuel in the tank.
Has anyone else experience/remedied this?
Old Aug 23, 2004 | 09:34 AM
cdelena's Avatar
Look at the MAP sensor fix.. odds are thats all you need to fix it.
Old Aug 23, 2004 | 09:57 AM
xviper's Avatar
If that doesn't work, then on to checking the plugs and gap. Then check the injectors (maybe try a bottle of cleaner) and then the fuel pressure. After that, things start to get complicated and possibly pricey.
Old Aug 23, 2004 | 02:01 PM
jjl02's Avatar
it could be your VTEC solenoid.... i had the same problem so i brought it into honda and they had to replace it.... just a suggestion.
Old Aug 23, 2004 | 02:19 PM
xviper's Avatar
Oh, another thought:
How's your oil level?
Old Aug 23, 2004 | 02:29 PM
s2kdarren's Avatar
ron I did a map sensor whack and it solved a lot of issues, i should have done it for u when we were at simons yesterday however im hoping the rest of my problems will be solved with a valve adjustment on friday from speedstar..... have u had a valve adjustment yet? i know your at like 60,000km already
Old Aug 23, 2004 | 02:30 PM
Bigsalgt's Avatar
My friend had almost the exact same problem on his S2, the only thing is it would happen every time he depressed the accelerator fully! When he took it to Honda they told him it was a clogged fuel filter from always running the car to empty. If your used to do doing that its a strong possibility that could be the problem. I have heard also that they should be changed every 20-25k, sounds right after all there only a $10-$15. Hope this helps!
marcrx5
Jun 9, 2014 05:52 PM
jet-s2k
Jan 2, 2011 05:03 PM
trebor
Mar 21, 2005 03:30 AM
chroot
Oct 23, 2002 12:54 PM
John MI blk/blk '01
May 3, 2002 03:39 AM
