Washer pump died?
Old Jan 23, 2008 | 11:36 AM
Sabre's Avatar
Default Washer pump died?
Hoping to get some insight on the washer fluid system.
I've done a little searching, but I'm at work and cant dedicate a lot of time to it.
This morning on the way to work, I tried to use my washers, and got nothing. I know the resevior should be full. I filled it about a week and a half ago, but need to double check as I have used it quite a bit. When I pull the stock to wash, the wipers go, but no fluid, and I cant hear the pump at all.
I'll be looking into it more tonight when I get home. But heck, why not get some advanced assistance from the wrenchers here.
What fuse should I be checking?
Pump is located behind the passenger front fender liner?
Any help is appreciated.
Old Jan 23, 2008 | 11:44 AM
skibum's Avatar
1. Check for fluid
2. Have someone pull the stalk and listen for whine coming from pump
3. Fuse diagram is on the back of the fuse panel cover - check fuse
4. Move out of Oregon and never use your wipers again.
Old Jan 24, 2008 | 03:39 AM
iam7head's Avatar
very well be a fuse problem, check your manual for the exact location
the proper washer fluid actually has a lubricate for the pump, although not all pump design take advantage of that.
bikky
Aug 19, 2014 03:22 AM
barnabylee
Jul 28, 2009 11:40 AM
evil MS3
Jul 14, 2009 11:32 AM
gtg749m
Apr 27, 2009 08:51 AM
s2krazy01
Oct 28, 2006 11:10 AM
