WATER INJECTION
Old Dec 17, 2004 | 06:43 PM
s2kboost's Avatar
Default WATER INJECTION
I was wondering who uses water injection, what kind of horsepower increase or intake temperature change.
Old Dec 18, 2004 | 02:49 PM
s2kboost's Avatar
i guess not
Old Dec 18, 2004 | 03:05 PM
AusS2000's Avatar
Have some patience. Unlike me not everyone lives and breathes S2ki.
As it happens fperra (IIRC) uses water injection. I'm also considering it. It doesn't "create" horsepower, it avoids detonation. That allows you to run more boost or leaner mixture and hence you get more horsepower.
Old Dec 19, 2004 | 05:10 AM
Hobbyholic's Avatar
Yes get more power from a transmission and rear diff that doesnt hold up..
Old Dec 19, 2004 | 05:28 AM
fltsfshr's Avatar
Drop fperra a note. He uses it in his turbo set up.
and you can do a search there should be several threads about water injection
fltsfshr
Old Dec 19, 2004 | 08:27 AM
fperra's Avatar
I used water injection with my UR turbo kit. I ran 9 psi with no timing retard and never had a detonation problem. When I pulled the head the pistons were like new. The best HP I got at 9 psi was about 311 and 238 ft -lbs. The tuning of the emanage was not perfect and the top end HP rolled off too early. I'm currently building a new turbo motor (see my sig) and I will use water injection with it. On the new setup I'll be able to read intercooler inlet temp and intale manifold temp. which should give a good reading on the benefits of water injection. I'll keep you all posted, but it will be a few month before I'm finnished. In the mean time, if you want to learn about water injection, go to this forum: http://www.waterinjection.info/phpBB2/
Old Dec 19, 2004 | 10:28 AM
JayStyles662's Avatar
I heard someone suggest to me that I go with Water / Alcohol...Anyone know anything about that?
Old Dec 19, 2004 | 05:38 PM
S2KPUDDYDAD's Avatar
Alcohol... At least on a Buick G/N OR GNX
Old Dec 19, 2004 | 06:35 PM
S2k_fever's Avatar
methanol mixed with water is used during the winter in colder climates.
Old Dec 19, 2004 | 08:06 PM
Elistan's Avatar
Yeah, pumps can't handle ice too well.
