Water on Intake
Old Mar 22, 2005 | 05:07 AM
JuanCarlos14's Avatar
Default Water on Intake
What are the chances of getting water into a Short Ram Typhoon Air Intake System by K&N?
Does that ever happen to anyone?
Is it possible to install the valve for intakes made by AEM into this intake?
Old Mar 22, 2005 | 05:47 AM
Gink5's Avatar
I'm not sure what intake you are talking about , so i can't comment on water in the intake. I do know that even if the valve fit on that intake it's not recommended. From what I've read the valve takes away from the sound and the little hp gain.
Old Mar 22, 2005 | 06:32 AM
S2kNY's Avatar
the chances are very unlikely that you will get water in any brand short ram intake, most of them are positioned right in the area where the engine sits. There is a higher chance witha cold air set up because these intakes are positioned near the ground where water is a lot closer to the filter.
Old Mar 22, 2005 | 11:18 AM
SIIK2NR's Avatar
The only way you would get water on a "short ram" is if you have vented hoods and hosed water on it or you lift up the hood and spray it directly.
As for the AEM bypass valve.....your wasting your time and money on a short ram. The bypass deletes any gains you would have got with any aftermarket intake.
Additionally the bypass has to be higher in elevation than the actual filter to work and it will only work when the entire filter is submerged causing negative suction to create airflow through the bypass.
In other words.......if your getting a short ram...it's fine....don't get the bypass.
Old Mar 22, 2005 | 11:56 AM
Thank you everybody for your answers. I appreciate all the info.
Old Mar 22, 2005 | 05:48 PM
JustJustin's Avatar
So are you saying that with a short ram intake he won't have potential for hydrolock? I was not aware the the shortys were immune to big puddles of water! (not driving through a flood, but heavy rain, puddles, high-way speeds, etc.) I would tend to agree with you about the bypass kinda defeating a short ram intake when they are essentially right next to each-other (if you soak the intake, you probably soak the bypass)
-Justin
Old Mar 22, 2005 | 05:52 PM
SIIK2NR's Avatar
Take the cover off your stock box.......it has the same chance of hydrolock as the short ram.
Old Mar 22, 2005 | 06:07 PM
JustJustin's Avatar
(I personally would not suggest it for any wet-weather driving!)
-Justin
Old Mar 23, 2005 | 09:18 AM
Bane's Avatar
grunyon
Jun 4, 2014 07:51 AM
dan_uk
Aug 12, 2010 01:36 PM
MeFryRice
Aug 4, 2008 10:34 AM
icemans2k02
Jan 31, 2007 05:39 AM
s2000honduras
Jun 15, 2006 12:55 PM
