Water used as a top engine cleaner?!
Old Oct 19, 2011 | 08:05 PM
eremoy's Avatar
Default Water used as a top engine cleaner?!
Today I came across a couple people talking about how great water is at "decarbonizing" engines when (very slowly) sprayed into the throttle body or sucked into the brake booster vacuum line, like you would with seafoam. I've never heard of such a thing. I mean, it just sounds like a bad and/or ineffective idea when you hear it for the first time. But to my surprise, when I looked it up alot of people seem to rave about how safe it is to use and how well it works. I'm not convinced. Still sounds like "an ole' trick" my grandpa would teach me or something. But really have any of you guys heard of this?
Old Oct 19, 2011 | 08:10 PM
speedjunky01's Avatar
It works very well
Tested with boroscope
Water/meth injected engines always look super clean when broken down
Old Oct 19, 2011 | 09:08 PM
SDgoods's Avatar
I guess it could be considered safe if you regulate very very cautiously how much goes in. ^^ in the case of water/meth injection it is regulated. The water literally boils(?) the carbon off. But if you let too much in you could risk a hydro lock at the very worst.
I'd feel sketchy about it too
Old Oct 19, 2011 | 09:28 PM
ahrmike's Avatar
Its not much different from seafoam. You put too much seafoam down your intake and it'll hydrolock as well.
Old Oct 20, 2011 | 07:32 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have seen it done...it was for an engine that was knocking due to carbon buildup on the piston, and it was hitting the cylinder head. It was some 4 cyl ford engine I remember.
While revving the engine very high (around 3500 on a 5500rpm redline engine) the guy dipped a large vaccuum line off the engine into a cup off water and sucked up a few teaspons. It broke up the carbon instantly and eliminated the knock.
I think its an extreme procedure and used for last resort repair.
KraZe_MY03
Apr 11, 2019 09:57 PM
JspecVtec
Dec 15, 2008 02:42 PM
REVN29K
Jan 7, 2003 10:38 PM
