Ways to check engine health?
Will an oil analysis (via Blackstone Labs) and a compression/leakdown test provide a reasonable synopsis of engine health before a used car purchase? What might you recommend or discount?
Visually inspect for fluid leaks. Pay specific attention to all of the liquid gasket seals between the oil pan, crank cradle, and the block.
Verify that all fluids are topped off. Somebody that lets this slide at the time of sale, probably didn't give a crap during the rest of the ownership period either.
Pull the spark plugs and inspect. Hate to admit it but the Chilton manuals have a nice tutorial on interpreting the tea leaves here.
Execute a compression test. A compression test will be a little more time consuming, but its a simple proceedure and only a $30 tool. This will give you some insight into the combustion chambers integrity.
LISTEN, LISTEN, LISTEN. Does the engine make unusual noises under load or during idle? Especially with internal components, there is no better indication of a failure.
Check the build-up on exhaust tips. Any soot which collects here will have a color... This can provide you very general information on the bias of tuning.
Originally Posted by under-rated,Nov 10 2004, 03:13 PM
Jerry, I just saw your sig... Berlina Black s2000, I ran into you a couple years back when I had my Spa Yellow near Northrup Wy. You had the comptech!!! Any other mods ?
Originally Posted by mikegarrison,Nov 10 2004, 05:13 PM
Jerry's got a special weight reduction mod on his car these days.
