Weak spark?
Old Sep 22, 2009 | 11:14 PM
EK9MAX's Avatar
Default Weak spark?
How can i find out if i have weak spark? I'm building a pretty big project and can't get this car to start. So I'm trying to eliminate the possibilities.
Pulled the coil and held it near the engine block. It sparks.... looks a bit weak thoguh, however i don't really knwo what i'm looking for....
I did relocate the battery.... But I checked all my grounds.
Old Sep 22, 2009 | 11:19 PM
SebRedAP1's Avatar
Push start it.
Old Sep 23, 2009 | 12:08 AM
Fast Jack's Avatar
IIRC u can tell if a spark is weak by the color of the arc.Boy had to search way back in my memory for dat one Correct me if I'm wrong but,orange/yellow=weak white/blue=strong.
Old Sep 23, 2009 | 12:15 AM
Fast Jack's Avatar
Also,the pro's are going to want more detail like: Engine swap and after-market mods.
Old Sep 23, 2009 | 09:07 AM
EK9MAX's Avatar
3mm head gasket
gt35r turbokit
1000cc injectors
aem ems
gm map sensor
I get fuel/spark/compression/timing looks good.
spark looked a little weak so i am just trying everything....
Old Sep 23, 2009 | 09:56 AM
Fast Jack's Avatar
FI forum might be of more help,in this case
Old Sep 23, 2009 | 11:20 AM
fuel4blood's Avatar
If you could see the spark it should (key word is should) be enough to ignite the air fuel mixture. I dont think your problems spark I would look elsewhere. As far as telling if you have weak spark, Im not sure about just looking at the spark but you can tell with a engine oscilloscope. No a easy tool to come by. Or a spark plug tester.
Old Sep 23, 2009 | 12:40 PM
EK9MAX's Avatar
But if it's really weak. The fuel might be blowing it out or something couldn't it?
i've tried 3 different sets of spark plugs.
Old Sep 23, 2009 | 12:53 PM
fuel4blood's Avatar
No its not gonna blow it out (it could be fouled if it was dumping fuel). I really don't think its plugs especially if you have tried three different sets.
it'S2klean
Jun 30, 2014 04:00 PM
cmn
Apr 15, 2010 08:53 AM
hypforlife32
Feb 5, 2010 06:56 AM
EK9MAX
Sep 27, 2009 10:35 AM
cvc2nr
Mar 16, 2006 02:21 PM
