Weird Grind
Old Apr 11, 2005 | 03:41 AM
cytokin's Avatar
Default Weird Grind
So I bled my clutch and replaced with ATE Super Blue Racing Brake Fluid.. DOT 4
The first time I started my car up it made a -small- grind noise. (sat)
It made the same noise yesterday when I started it up. (sun)
Please let me know if I broke something
Anthony
Old Apr 11, 2005 | 04:19 AM
Slows2k's Avatar
Bleed the clutch again, sounds like you still have air in the system.
Old Apr 11, 2005 | 04:21 AM
cytokin's Avatar
Okay!
Thanks.
Old Apr 11, 2005 | 09:32 AM
cytokin's Avatar
Anyone else?
Old Apr 11, 2005 | 03:00 PM
Slows2k's Avatar
Have you bled it yet?
Old Apr 11, 2005 | 05:44 PM
cytokin's Avatar
Haven't had a chance to yet. It hasn't made the noise again either.
Old Apr 11, 2005 | 07:19 PM
Utah S2K's Avatar
Air migrates up......even in a closed system. Your system probably cleared itself....but you should check for two things:
1) No leak at the bleed valve
2) Recheck the fluid level in the reservoir and top up. Most likely the bubble ended up here.......
Utah
Old Apr 12, 2005 | 04:05 AM
cytokin's Avatar
Thanks! Also, when you push in the clutch while in gear, does it make a slight squeeky noise? Normal??
Thanks again,
Anthony
Niuniu32
Feb 17, 2017 06:42 AM
fastD
Feb 23, 2015 03:41 PM
mrpoopiehead
Sep 2, 2014 06:32 PM
s2k-tilldeath
Oct 9, 2013 08:43 AM
DERF
Aug 16, 2006 03:50 PM
