Weird Noise (Engine)
Old May 11, 2013 | 03:07 PM
Themikewoo's Avatar
Please post the solution
Old May 12, 2013 | 01:09 PM
jl56tc's Avatar
sounds like a "rotter gerder" or a "Muffler bearing"..... ROTFLMAO .... yeah make sure you post a solution
Old May 17, 2013 | 11:14 AM
BlackCL's Avatar
OK. Took it to Honda and the only thing he could figure out was 2 bottom motor mounts were torn. Took the car back to the body shop and they found out that the noise is coming from behind the firewall. Now they are taking the car apart to see what it could be. I will find out on Monday.
Old May 17, 2013 | 11:17 AM
SilverS2kF22C1's Avatar
You happen to loose your oil cap? it has a habit of ending up between the transmission tunnel and the firewall also...
Old May 17, 2013 | 03:50 PM
BlackCL's Avatar
When I got an oil change done at NTB last year, I noticed later during the day that they had forgot to put the oil cap back on. I went to Autozone and just bought a new one. Could that oil cap had been stuck in there for a while, and now stuck between the transmission tunnel and firewall after the accident? Any picture of what that area looks like? So I can check with a flash light. Thanks.
Old May 17, 2013 | 03:59 PM
AZ-S2000's Avatar
A few things:
  • Cat?
  • Exhuast mount?
  • Trans mounts?
  • Loose DOHC VTEC Cover? (Mine did this - Sounded similar, forgot to put the bolts in)
  • Check driveshaft bolts if they're loose? (Happened recent, also sounded like this)
Old May 18, 2013 | 02:24 AM
I would go looking then. I dont have pics and not sure you can even see it. Try a search for oil cap or something. It has happened to others and there have been posts.
Sent from my SCH-I605 using Tapatalk 2
Old May 21, 2013 | 09:58 AM
BlackCL's Avatar
One mechanic just told me it's the flywheel.
Old Jun 4, 2013 | 04:44 PM
BlackCL's Avatar
SOLUTION!
After changing both the motor mounts, the problem is finally GONE!
Car feels good again =)
Pancheezy30
Dec 25, 2018 03:00 AM
Mooseman
Sep 11, 2011 08:33 PM
Dark
Jan 8, 2007 06:26 AM
THAT K1D
Dec 17, 2006 07:28 AM
S2000_Hokie
Aug 22, 2001 12:42 PM
