weird O2 sensor problem no codes
I have a 2004 S2000 pretty much stock. a few weeks ago my car started dbogging down when I pressed the accelerator. No codes, the obdII testor shows both O2 sensor voltages drop to zero when it happens... any ideas?
The car is leaning out severely. which is why the voltage from the O2 is dropping. So the system is not gettting enough fuel at higher throttle. So not a O2 sensor problem since you are seeing a running issue that corresponds to the O2 sensor reading.
I'm beging to think ECU, but I hope not, any ideas brilliant Honda whisperers?
That's why I didn't just replace o2 sensors, if it had been just one, maybe... But both at the same time?WTF? They aren't Daisy chained (fed by same heater line are they?)... And it only happens after the car has been running fine for about 10 minutes.
ECU is almost never the cause of an issue in a modern car. My father has owned and operated a shop longer than ECU's have been used in cars, and he has found the ECU to be the actual issue in probably less than 10 cars ever.
There really is not a reason to think the ECU or sensors are bad here. Likely, you actually have a condition where the car is leaning out under heavy throttle application. Could be injectors or anything in the fuel delivery system really. Just because it has not set a code does not mean the ECU is not working properly.
Kshawn
Feb 17, 2019 02:14 PM
