Weird Problem
Old Oct 1, 2011 | 02:47 PM
s2000maniac's Avatar
Default Weird Problem
My s2k is not my daily driver so I take it out for a drive every other weekened. Today I went it for a drive and whenever I went WOT I could smell sort of fuel/burning . My03 with 136000 miles. My mods are PLM header, Invidia 70mm test pipe, and Invidia q300 exhaust. Last time I took it for a drive I didnt smell anything. I got no leaks, no CEl's, no nothing. Any ideas?
Old Oct 4, 2011 | 03:12 PM
anyone? could it be an exhaust leak?
Old Oct 4, 2011 | 03:43 PM
RacerXI's Avatar
My car smells like gas all the time. I'd say check for leaks under the car and the hood. Also check to see all hoses are hooked up with no leaks. I doubt it's anything, but you can never be too careful.
Old Oct 4, 2011 | 05:03 PM
the thing that worries me is that it didnt do this before. it started all of a sudden, even my buddy noticed it.
Old Oct 4, 2011 | 05:27 PM
SDgoods's Avatar
you have a test pipe. With out a cat your inevitably going to smell fuel. Im surprised you hadn't smelt it before.
Did it happen to be during cold start when you're running even more rich then normal?
Old Oct 4, 2011 | 06:42 PM
during normal driving, as soon as I step on the throttle I smell fuel/burning. I never smelt this before and I have had my test pipe for a while, and recently installed the header.
Old Oct 4, 2011 | 06:58 PM
SDgoods's Avatar
Hmm, i mean its pretty normal to smell fuel with out a catalytic converter. Maybe take a peak under the hood and underneath and just double check for leaks, disconnected vacuum lines, etc... If not maybe have another owner with a test pipe take a ride and verify that its normal, or take a ride in their car. Hope that helps
Old Oct 4, 2011 | 07:10 PM
D-Jetronic's Avatar
If you got no cats, you will smell gas fumes.
If your car got an exhaust leak before the cat, you will smell gas fumes.
If your car just got started, you will smell gas fumes until it running at normal operating temperature.
If you got a gas leak, you will smell it also.
That's about it.
S2K_Gabe
Apr 14, 2018 03:07 PM
USMC s2k
Jun 2, 2012 05:15 PM
vtec4life57
Aug 27, 2010 12:37 AM
davidvonyork
Sep 25, 2006 12:51 PM
Congo
Mar 21, 2006 09:10 PM
