Weird rubbing sound from the rear..
Old May 28, 2015 | 12:29 AM
zzz's Avatar
zzz
Default Weird rubbing sound from the rear..
Hey guys,
I've got this weird sound every time I'm driving, when ever i'm rolling it sounds like a rubbing sound.
At first i thought it was my wheel rubbing against the fender liner, but i've check all that..i'm either thinking its a wheel bearing or the diff
Has anyone every had this problem before ?
VIDEO OF THE NOISE
Here's a video as a example..
ALSO when i'm in gear and decelerate, i'm having a high pitch grinding sound as I let go of the clutch in gear, i'm thinking it could be a bearing in the gearbox, pretty sure it isn't clutch buzz as i've just recently replaced the clutch and slave and master with OEM units.
Will post video if necessary..
Thanks
Old May 28, 2015 | 06:56 AM
windhund116's Avatar
Brake noise, perhaps?
Old May 28, 2015 | 06:21 PM
NoMoreCivicsPlease's Avatar
Sounds like brakes. I can have the car off and roll backwards, I hear a slight slight scrapping sound like that
Old May 30, 2015 | 06:04 AM
jinglis's Avatar
I had a similar sound. It was coming from the rear left wheel. It turned out to be the hub. I had the hub bearings replaced on both rears as well replacing the worn hub.
Things that I noted: I thought it might be the brake caliper or the hub bearing. It seemed to be related to rotational heat generation i.e. drive a short distance no noise, more than 5-10 minutes it would start. It was most pronounced when coming off the power and slowing down, then would almost disappear when applying power again.
Old May 30, 2015 | 07:13 AM
nissanfanatic's Avatar
If you can't manipulate it with the brakes/hand brake, it is probably a wheel bearing/hub.
Typically you can manipulate wheel bearing noise with cornering/side loading.
Old Jun 28, 2015 | 06:31 AM
harryw66's Avatar
Hi,
Did you resolve this problem?
Sounds very much like the sound mine is making.
Does the sound change as you go faster? e.g. 60mph.
Thanks!
ljsimp
Jul 5, 2012 04:55 PM
AliasMrJones
Mar 13, 2011 04:06 PM
Siggy
Apr 18, 2010 09:15 PM
Honda Life Dunk
Feb 19, 2009 03:47 PM
ERL_S2000
May 2, 2006 07:10 AM
