Weird Throttle Problem (non-issue)
Old Dec 6, 2013 | 03:08 PM
TommySalami's Avatar
Default Weird Throttle Problem (non-issue)
Edit: nothing was wrong. Greddy EMU exaggerated the sensitive throttle behavior this car has
Old Dec 9, 2013 | 09:37 AM
modifry's Avatar
Honorary Member
You didn't mention the year of your car so I'll assume it's not DBW.
Did you measure the TPS voltage at idle? I know you changed the throttle body, but that doesn't mean the new one is working properly. Since you mentioned it does not rev smoothly in neutral, I would put a meter on the TPS and make sure the TPS voltage smoothly increases as you manually open the throttle by rotating it from under the hood.
Have you checked for a vacuum leak?
Daremo
Apr 8, 2016 10:46 AM
JimmyB
Jul 18, 2007 11:07 AM
6sigma
Aug 1, 2003 09:57 PM
