What is the best mod? HELP!!!
Hello there, i have some ideas for my mods and i would like you to help me out. I ,so far, have only changed my air filter (AEM) . I have the AEM Plug and Play ECU and the spoon head-gasket but i have not yet installed them. I was told that i need to change the valve springs and the valves too but i believe that the Spoon polished valves do not have a big difference with the stock ones. I am also thinking of adding camshafts, Toda or Spoon.
I read somewhere that Spoon camshafts are not in production anymore, is that true?
What is the difference with the Toda version 1 and version 2 camshafts. Can both versions be installed with a Spoon head-gasket? What would be the best combination of mods. Putting my head-gasket and polishing my engine (enlarging the inputs/outputs of the air/fuel flow by hand) and valve springs or finding appropriate cams to go with the head-gasket?
What would be a better mod for power gain and reliability?
With these mods will it be necessary to change my clutch kit and add a flywheel?
I will appreciate all answers that come from people who have a good knowledge in mods. Thanks.
The Spoon cams seem to just be a myth, and the version 1 Toda cams aren't available anymore. I think Toda V2 spec A cams can be used with a thinner gasket without valve / piston contact. I don't know about the Ti valves, but I don't see why they wouldn't work. However, you do have to use stiffer valve springs.
Does any one actually know if I will have valve/piston contact with the spoon head-gasket and the TODA cams v2???
What is the exact space left between valve/piston after haed-gasket and TODA cams???
It is amazing what you can find in 30 seconds using 'Search'.
http://forums.s2ki.com/forums/showthread.p...=toda+cams+spec
S2000_Europe
Mar 1, 2003 07:58 AM
