What happens if you try and put 1' O2 sensor in
Old 11-26-2006, 07:17 AM
CKit's Avatar
Default What happens if you try and put 1' O2 sensor in
Was running a little rich and caused the early demise of my secondary (post-cat) oxygen sensor.
Went to the local auto parts store and they recommended a Bosch universal #15730.
Put the car on jackstands, spliced in the part...
Then found out they had given me the part for the PRIMARY O2 sensor instead!
I needed Part # 15734. They've ordered one for me. No charge of course.
My question is: what will happen if I run the #15730 in the secondary location? Will it work okay? Do they have different resistors? Will it turn the CEL off?
I don't want to jack up the car to remove the O2 sensor again (at least until the right part comes in), but I don't want to damage anything in the meantime.
Thanks!
Old 11-26-2006, 07:28 AM
Slows2k's Avatar
The heater elements are different resistances. The OEM sensors have different connector shells that won't let you swap them.
Old 11-26-2006, 07:38 AM
CKit's Avatar
Unfortunately the universal ones are just spliced in. I guess I'll just remove it and put it aside for when the primary eventually goes.
Thanks for the quick reply!
Swiftoy
05-18-2015 09:27 AM
2d-ink
01-01-2014 04:26 PM
Bkclark
05-26-2012 05:15 AM
S2000_Europe
02-20-2004 09:04 AM
Quick Reply: What happens if you try and put 1' O2 sensor in
