what the heck is this?
Old Jun 13, 2007 | 10:35 AM
FISH22's Avatar
Originally Posted by SilverDC2 AP1,Jun 13 2007, 10:25 AM
no, its just a rubber than keeps it from swaying too much., kinda like a bumpstop.
right, but these are still somehow connected to the frame...if they werent, the sway bar would be useless.
Old Jun 13, 2007 | 09:17 PM
jyeung528's Avatar
that statement isn't true.
i think you are thinking of how strut bars work...which is to reinforce the chassis rigidity.
sway bars do not reinforce chassis rigidity...they provide momentum to transfer from inner wheel to the outer wheel, thereby reducing chassis sway.
Old Jun 14, 2007 | 02:00 AM
RACER's Avatar
The anti roll bar (or sway bar as it is also refurred to) is bolted to the frame, or subframe in this case.
#7 in the pic is called the STABILIZER HOLDER BUSHING, #2 in the pic is called the FR. STABILIZER BRACKET. This is where the bracket fastens the anti-roll bar to the sub frame.
Originally Posted by Slows2k,Jun 13 2007, 05:12 AM
stop collars that keep the bar from sliding sideways in the bushing #7
This is partially true. Being that both ends of the anti-roll bar are firmly attatched to the knuckels, they can't really move side to side very much. The stop collars are pretty much there as a means of fixing the anti-roll bar to the sub frame of the car's chassis.
Old Jun 14, 2007 | 02:07 AM
RACER's Avatar
A pic of the front anti-roll bar.
Notice the extra part #8, the STABILIZER HOLD BRACKET. The anti-roll bar attatches to the bracket, (#8) and the bracket bolts to the sub frame.
Old Jun 14, 2007 | 03:38 AM
Slows2k's Avatar
Would you like to remove the collars from my gendron bar and see how much the bar can slide in the brackets?
Old Jun 14, 2007 | 03:49 AM
RACER's Avatar
I'm sure it would move side to side a bit, but if the collars were unbolted, the bloody anti-roll bar would be 100% useless
Old Jun 14, 2007 | 04:33 AM
Slows2k's Avatar
If the collars where not there the end links would hit the front shocks.
The bracket that holds the bar the the chassis is a separate part, as is the bushing the bracket bolts over. The collars are on the outside of the bushing.
Old Jun 14, 2007 | 04:40 AM
RACER's Avatar
Originally Posted by Slows2k,Jun 14 2007, 05:33 AM
The bracket that holds the bar to the chassis is a separate part
Correct.
That's pretty obvious in the pic.
Old Jun 14, 2007 | 04:48 AM
Slows2k's Avatar
If you understand those 2 points what's the problem then?
Old Jun 14, 2007 | 04:59 AM
RACER's Avatar
I never insinuated there was a problem
[QUOTE=Slows2k,Jun 13 2007, 05:12 AM]stop collars that keep the bar from sliding sideways in the bushing #7
S>>capades
Feb 10, 2015 03:30 PM
tekstar
13
Apr 21, 2008 09:13 PM
KJ1225
Mar 22, 2007 05:13 PM
SlidinS2k
Mar 12, 2007 07:18 PM
joecro
Jan 22, 2001 06:23 PM
