What is this knocking/tapping?
Old Jun 3, 2013 | 01:58 PM
jordannn93's Avatar
Is there anything else to check while I have the bottom end opened up ?
Old Jun 3, 2013 | 01:59 PM
BLAQ&GREYs2k's Avatar
I see you wearing gloves and pulled the bearings yourself. Did you also do the valve adjustment yourself? Not judging your abilities as a valve adjustment is pretty straight forward, but did you have a bad feeling about any of the valves? Possibly one is too tight? Another consideration is the TCT failed, even though it sounds like rod knock.
Old Jun 3, 2013 | 02:00 PM
Actually, did you happen to check the top half of the bearings on each rod? The ones pictured show typical wear, nothing that is causing your noise. You will know a bearing is bad when you see it lol
Old Jun 3, 2013 | 02:08 PM
jordannn93's Avatar
Billman did valve adjustment in March. I didn't check the top half of the bearing. I did the diy tct fix back in November but I can look again. My oil/pan had not much metal in it. Like nothing really big or alot. Very very small amount.
Old Jun 3, 2013 | 02:43 PM
jl56tc's Avatar
sounds like my main bearing (crank bearing) did... crappy dude
Old Jun 3, 2013 | 02:58 PM
jordannn93's Avatar
Is there a way to check this ?
Old Jun 3, 2013 | 04:31 PM
You'd have to find an official service write up for it but if im not mistaken, the crank is sandwiched between two halves of the engine block. Not sure if it can be disassembled from the bottom end this way though...
Old Jun 3, 2013 | 05:22 PM
jl56tc's Avatar
Originally Posted by BLAQ&GREYs2k
Originally Posted by jordannn93' timestamp='1370300324' post='22584507
[quote name='jl56tc' timestamp='1370299424' post='22584476']
[/quote]
No way I tried a few diffrent ways.. pull the engine was the winnner
Old Jun 3, 2013 | 07:55 PM
jordannn93's Avatar
Just took valve cover off. No metal shavings. Looks normal under there .
Old Jun 3, 2013 | 08:23 PM
s2000maniac's Avatar
check out the vtec solenoid screen
