What to replace after airbag deployment on 2007 s2
Old Jan 16, 2009 | 05:18 PM
crits2k's Avatar
Default What to replace after airbag deployment on 2007 s2
So the drivers airbag went off and there wasn't a passenger in the car so the passenger side did not go off. What do I need to replace? The passenger side seatbelt still functions normally as no one was in that seat, do I need to replace it? The drivers side seatbelt is locked so I know I need to replace the SRS unit, the drivers side airbag and seatbelt, do I also need to replace those two sensors on the front of the frame rail?
Old Jan 16, 2009 | 05:41 PM
Slows2k's Avatar
You need a drivers bag, SRS unit, and drivers seatbelt tensioner.
03's don't have separate impact sensors.
Old Jan 16, 2009 | 11:00 PM
crits2k's Avatar
I'm working on an 07 as stated in the topic title, it has separate impact sensors.
Old Jan 17, 2009 | 06:44 AM
Slows2k's Avatar
Then you'll need both impact sensors
Old Jan 17, 2009 | 08:09 AM
crits2k's Avatar
Gotcha, thanks. Glad they are not as expensive as the srs ecu
Old Jan 17, 2009 | 09:23 AM
s2000cr's Avatar
Don't need to replace impact sensors if they are not damaged. You can reflash the ecu for 50-100$ at most places to save you from having to buy a new one. Seat belt needs to be changed only if it has been locked. Replace the blown airbag and you are good to go!
Old Jan 17, 2009 | 09:40 AM
Slows2k's Avatar
SRS units can not be reflashed. Once a bag has deployed the unit is a paperweight.
Impact sensors are also 1 use only items.
Old Jan 17, 2009 | 09:44 AM
IlleztImportz's Avatar
Old Jan 17, 2009 | 01:55 PM
s2000cr's Avatar
YES they CAN be reflashed. They work perfectly fine after the fact. Having had at least a dozen of them reflashed for multiple cars ranging from hondas to lexus, I know they can be reflashed. Impact sensors for honda can be reused if they are not damaged.
Old Jan 17, 2009 | 02:34 PM
RedY2KS2k's Avatar
So help the guy out and suggest a place that can do the reflash for him.
