What is this on the side driver brush?
Old Oct 18, 2011 | 04:52 AM
soichiro77's Avatar
Default What is this on the side driver brush?
Hello
Nobody can say to me what is the thing on the brush on the picture?
Old Oct 18, 2011 | 05:17 AM
Reckon's Avatar
What is it from (area)?
Old Oct 18, 2011 | 05:23 AM
soichiro77's Avatar
it is on the driver bursh and it is connected to electrical fil.
I will post more precilsy picture tonight of what i want to say.
Old Oct 18, 2011 | 05:29 AM
mister_two's Avatar
Not 100% sure but it may be the nut to adjust where the soft top stop when it's in the down position. For the early models MY00 there was a bulletin detailing how to adjust how low the softtop sits when in the down position. This nut bolt may be the adjustment for the that. You needed a crowfoot wrench to adjust this nut. I had to do this years ago because the softtop was sitting too high when in the down position so it was pushing against the tonneau cover and rear tabs would keep coming off.
Old Oct 18, 2011 | 05:34 AM
soichiro77's Avatar
Yes mister two, i think it is that you are describing.
But i remove the brush and so this in order to put my Hard Top. Is there consequences?
Old Oct 18, 2011 | 06:04 AM
mister_two's Avatar
You should look up the DIY on hardtop installation. Whether this part is needed or not with a hard top I can't say. Are you planning to use the hard top permanently ? And completely removing the soft top? If this is the case may be you don't need this part but again I don't know for sure. I have a hardtop and as I recall the brush part is still there.
Old Oct 18, 2011 | 06:12 AM
soichiro77's Avatar
Maybe, i need this only if i use the soft top. I think i dont need it with hard top. I hAD to remove the brush with the hard top because, if i let it, i wasn't able to replace the side plastic.
Old Oct 18, 2011 | 07:49 AM
JackS's Avatar
There are seperate brushes that go with the HT. I don't know what that piece is that you are showing. Maybe it's some kind of homemade adjustment? Anyway, contact a dealer and order a set of correct brushes. they are cheap.
preworkoutdrive
Jul 19, 2015 04:02 AM
S2What
Sep 9, 2013 05:44 AM
ragweed316
Apr 10, 2009 08:32 PM
suterusu
Apr 22, 2006 10:31 AM
