What's normal coolant temperature?
Old Sep 18, 2002 | 08:27 AM
Gernby's Avatar
Former Sponsor
Based on UL's post, you should have it checked. He knows more about this stuff than anyone.
Old Sep 18, 2002 | 08:28 AM
HARDtoTOP's Avatar
Ok, how are people reading the OBD2 sensor indication? Is there a particular gauge that can be tapped into the signal and get a reading? Thanks
Jeff
Old Sep 18, 2002 | 08:29 AM
Gernby's Avatar
Former Sponsor
Originally posted by peterwusc
I don't think it reached 4 bar... I usually look at the temp gauge instead so I didn't note the bars on the panel...
One more thing. Does anyone know where does the stock coolant temperature sensor locate?! The coolant temperature I quoted is reading directly from the ECU, which may be quite different from temperature measured at radiator or coolant tube that normally aftermarket sensor will be installed.
If you have an aftermarket temp guage, and the sensor is installed in a way that restricts flow, then that could be your problem.
Old Sep 18, 2002 | 08:32 AM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by sireousrex
[B]Ok, how are people reading the OBD2 sensor indication? Is
Old Sep 18, 2002 | 12:27 PM
9906's Avatar
Gernby,
It seems to me that you have too many variables to make an apples to apples comparison in this worthwhile effort. How did you separate the insulating effect of the Hondata gasket from the impacts of the Mugen parts?
Old Sep 18, 2002 | 12:34 PM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by 9906
[B]Gernby,
Old Sep 18, 2002 | 12:51 PM
9906's Avatar
[QUOTE]Originally posted by gernby
[B]
Don't get me wrong here.
Old Sep 18, 2002 | 01:01 PM
Gernby's Avatar
Former Sponsor
[B]
OK, got it.
Old Sep 18, 2002 | 08:52 PM
peterwusc's Avatar
[QUOTE]Originally posted by ultimate lurker
[B]During normal driving using the OBDII coolant temp sensor (the only one the ECU cares about) the numerous S2K's I've tested will see 180-185 F coolant temps.
Old Sep 19, 2002 | 02:06 PM
Gernby's Avatar
Former Sponsor
I did a search for more info on this, and found them here:
http://www.technosquareinc.com/cmxh2.htm
Another KICKS ASS product from this is this thing that will log OBDII data to VIDEO!
http://www.technosquareinc.com/vlogger.htm
tozerman
Sep 25, 2013 07:15 AM
S2000_FUN
Mar 16, 2011 12:34 PM
Spec_Ops2087
May 2, 2010 02:33 PM
medicalstudent
Mar 1, 2005 07:51 PM
S2K_Spain
Feb 26, 2001 02:36 PM
