What's wrong?
Old Apr 22, 2010 | 12:13 PM
dammitjim's Avatar
Originally Posted by Dr. Strangelove,Apr 22 2010, 01:42 PM
I took the car to get the diff oil changed at the dealer
What fluid did they put in the diff?
https://www.s2ki.com/forums/index.php?showtopic=115704
Old Apr 22, 2010 | 12:28 PM
Dr. Strangelove's Avatar
@Saki GT It is the stock AP2 Exhaust
@dammitjim No idea. about the diff fluid. It doesn't seem to be transmission related noise though, because the pitch doesn't change with speed or gearing.
Old Apr 22, 2010 | 12:31 PM
dammitjim's Avatar
I turn the wheel, brake, clutch change gear, throttle position, nothing changes it, except it seems like it sputters a little when i got over short bumps in the road.
Does it do it when you're at a stop with the car running? Same thing at a stop with the car in key position 2 but not running?
Old Apr 22, 2010 | 12:32 PM
Haven't been stopped yet while the problem is going on. It's really random when it comes and goes. I'll try that next.
Old Apr 22, 2010 | 12:35 PM
dammitjim's Avatar
This
https://www.s2ki.com/forums/index.ph...ic=768736&st=0
https://www.s2ki.com/forums/index.php?showtopic=449105
Old Apr 22, 2010 | 12:48 PM
Ha ha ha! If it's a sticker... I'll run out and check my car on my break in a minute.
I called the dealer and I am going to drop my car off tomorrow morning. The bent brake dust shroud and wheel speed sensor sounds like a pretty likely culprit.
Old Apr 22, 2010 | 10:05 PM
Well the sticker did it! Pulled it off and the hissing went away.
Now I just have to figure out what is wrong with the VSA system. I got it to go again today and it was the brake light and the two VSA lights. We'll see what they say. I'm kind of betting on a faulty sensor.
Old Apr 23, 2010 | 08:08 AM
ace123's Avatar
good call, dammitjim!
Old Apr 29, 2010 | 01:53 PM
dammitjim's Avatar
What was the cause of the VSA trouble?
smcconnell13
Aug 29, 2016 10:32 AM
Evofusion
Nov 5, 2009 10:18 PM
VTEC Racer
Jul 25, 2008 10:48 AM
armeN
Aug 24, 2007 11:13 AM
MrM
Nov 15, 2006 02:17 AM
