Wheel Nut spec
Old Sep 23, 2004 | 12:19 AM
jwkim's Avatar
Former Sponsor
Default Wheel Nut spec
Some Honda uses M12x1.25 and S2000 uses M12x.1.5
What does 1.25 and 1.5 stands for? depth?
can I fit both on same car??
TIA!
Old Sep 23, 2004 | 09:28 AM
Elistan's Avatar
Won't fit. They have different thread pitches. My understanding of how these things works is this:
1) The first number (12) is the diameter of the threaded portion (not the head, so it doesn't tell you what size socket to use.)
2) The second number is the thread pitch - in metric bolts, it's how many mm seperate each thread. The higher the number, the coarser the thread.
Bolt trivia - you only need the first six threads to get the full fastening strength of the bolt.
Old Sep 23, 2004 | 10:24 AM
alexf20c's Avatar
Also, for metrics, if the pitch is not indicated, it's a coarse thread (1.5).
Sometimes, the bolt will be listed as M12x1.25-40. The 40 indicates the total thread count. From this, you can calculate the bolt length: 40 x 1.25mm = 50mm.
EDIT: Or does '40' indicate 40mm thread length?
Old Sep 23, 2004 | 10:31 AM
PLYRS 3's Avatar
"stem" length??
Old Sep 23, 2004 | 09:13 PM
xviper's Avatar
Look here:
http://mdmetric.com/tech/tic1e.htm#helpnote
MWoolley
Aug 1, 2019 12:51 PM
street_ruler
May 23, 2015 01:11 AM
S2k Eire
Sep 23, 2009 04:39 AM
Aze85
Jan 26, 2005 04:25 PM
