stripped thread.
Old Jan 24, 2005 | 08:43 PM
Aze85's Avatar
Default stripped thread.
i was installing my x brace andi stripped the thread in the hole. i wasnt using much for at all, just hand tightening it. what should i do? how can you repair it? my dad used to be a mechanic and said that i needed to get a rethreading tool that is one size bigger than the original thread and rethread the hole. that would require me to use a larger bolt also. is there any other way???
help me please!
Old Jan 24, 2005 | 10:58 PM
Bane's Avatar
Before you drill it out and use a larger sized tap...
Try using the correct size tap for the hole to see if it will clean the threads up enough to allow the bolt to thread in.
Old Jan 25, 2005 | 03:59 AM
Aze85's Avatar
thanks. i think im going to end up taking my car to a ultimate. its a local shop that does quality work. hope they can do it right.
thanks for the reply!
Old Jan 25, 2005 | 04:45 AM
gfacter's Avatar
help me please!
Like I said in your earlier post. You need a Helicoill kit, it will allow you to use the exact same bolt.
That is the proper way to fix a stripped bolt hole.
You need to figure out the thread size and pitch before you purchase the helicoil kit.
This explains the process
Helicoil
Old Jan 25, 2005 | 11:08 AM
Aze85's Avatar
thanks! i will look into it and mayeb i will do it myself.
Old Jan 26, 2005 | 04:25 PM
RT's Avatar
RT
use a longer bolt to get to some "good" threads
MWoolley
Aug 1, 2019 12:51 PM
street_ruler
May 23, 2015 01:11 AM
jwkim
Sep 23, 2004 09:13 PM
Pdubb
Jun 27, 2004 06:07 PM
