Where is This Leak From?
Old Apr 21, 2014 | 01:34 PM
DrakeValle's Avatar
Man, I know those bolts are huge or anything, but shearing them of at 8.7lbs seems crazy.
I had to double check that I had my torque wrench set correctly the first time I torqued bolts that low because it felt like I barely turned them.
Old Apr 21, 2014 | 01:39 PM
baZurk's Avatar
I tighten mine with a 1/4" socket wrench so that I don't over torque them haha
Old Apr 21, 2014 | 03:03 PM
S2KIrishman's Avatar
I don't understand why you think it would be ok to drive it like that...youre missing 60% of the parts that hold the valve cover down ...if you thought it was ok to drive like that, I would have someone who knows what theyre doing double check your valve adjustment to make sure you didn't f@#k anything else up...motors are expensive to replace
Old Apr 21, 2014 | 09:02 PM
anamono's Avatar
Originally Posted by CoolGuy094
You absolutely need to fix the valve cover bolt issue. You're missing three out of five bolts, and all the missing ones are at the corner where you're seeing the leak. Get a bolt extractor kit and start working on removing the three sheared bolts. Order five new valve cover bolts.
Originally Posted by baZurk
That is almost guaranteed to be your problem. You can also remove your cam caps and see you you can wiggle those bolts out before you try to extract them and possibly damage the threads on the cam caps.
Originally Posted by DrakeValle
Man, I know those bolts are huge or anything, but shearing them of at 8.7lbs seems crazy. I had to double check that I had my torque wrench set correctly the first time I torqued bolts that low because it felt like I barely turned them.
Guys, I think you misunderstood me. The FIRST thing I want to do is fix the sheared off bolts problem. But I started this thread thinking this leak could be from something else. I already had an order ready to go for the sheared off bolts. But I just wanted to confirm if the leak is from something else. Cause if it was and ordering parts was necessary, then I would them add them to the same order. I should've mentioned the sheared off bolts in the beginning. That's my bad. But I think I just wanted everyone who's chiming on the cause of the leak to give me other possible causes than the sheared off valve cover bolts.
I ordered a set of 5 valve cover bolts, valve cover gasket and rubber grommets, spark plug tube seals just in case, and the cam cap holder bolts. The cam cap holder bolts are because the bolts sheared off deep in the hole and I'm not comfortable with tapping into them. I have PM'd Billman about it and he said it was okay to just replace the 3 cam cap holder bolts without having to replace the other ones. Just loosen them in sequence and tighten them to torque spec in sequence. But he also suggested that I could probably remove the broken part of the valve cover bolts with a dental pick. But I'm not exactly sure how to do that.
My valve cover is coming off again as soon as I get the parts.
Old Apr 22, 2014 | 10:21 AM
CoolGuy094's Avatar
Sounds like a plan. Get that problem fixed first. Then clean up that oil and drive the car around to see if the leak persists. My guess is that it won't.
Old May 5, 2014 | 08:56 PM
anamono's Avatar
Just a little update. So finally fixed everything up. Changed my valve cover bolts. Had to replace the cam cap bolts since the broken ends of the valve cover bolts were pretty deep in there and hard to extract. Also, I thought since I'd have my valve cover off again, I'd do my retainers too. Two were cracked. One of them was pretty bad but to my surprise I couldn't tell without taking them off. The keepers were not sunk in as far as I could tell. Also tightened my oil filter with a socket cause I've read horror stories about them coming off. Car ran great! No more leak. Autocrossed it this weekend.
Here's a picture of my new addition to my keychain!
s2000maniac
Apr 11, 2012 05:42 PM
kylemonster85
Jul 18, 2007 09:02 AM
Tuanster
Nov 20, 2006 07:56 AM
Veneficus
May 10, 2004 06:56 PM
minboost
Sep 12, 2002 03:28 AM
