White liquid over the top of the engine
Old Feb 16, 2004 | 06:51 AM
masamune's Avatar
Default White liquid over the top of the engine
Guys
can anyone tell me what is wrong with my engine.
The little circular plastic thing in the middle of the red engine cover is covered in a solidified white liquid, it has also splashed on the pipes below.
thanks
Old Feb 16, 2004 | 07:14 AM
Road Rage's Avatar
R U 4 real?
Is it a powdery material? - likely coolant - the car either overheated or some moron removed the radiator cap to look at it - if you see a blind person with the same material all over his face, you will have your answer.
Old Feb 16, 2004 | 07:57 AM
Squeezer's Avatar
is the little circular thing you are talking about the PCV valve? if so, white stuff on it is not good at all. take off your radiator cap when the engine is cold. if you have an )) is it green? if you have an 01+ is it red? if it looks bubbily or muddy you have a problem. take off the valve cover? are the cams covered in dark brown oil (good) if not you have serious problems.
Old Feb 16, 2004 | 02:13 PM
hboy7777's Avatar
pictures would help very much. someone will most likely have an answer for you here if they can see the problem.
Old Feb 16, 2004 | 03:05 PM
alwayzspeedin's Avatar
Banned
its man juice damn your sick i know you love your s2000 but damn man relax......jk
Old Feb 16, 2004 | 03:18 PM
vananron's Avatar
Sounds like a civic owner saw your engine bay.
Old Feb 16, 2004 | 05:47 PM
fly_S2K's Avatar
Old Feb 16, 2004 | 11:01 PM
masamune's Avatar
guys
thanks for the feedback
yes its white and powdery, and inside the radiator cap is green liquid, does this mean my engine is dead? its only done 4000 miles!
is it safe to assume that my engine will fail prematurely?
Old Feb 17, 2004 | 04:54 AM
Squeezer's Avatar
as long as its green with no muddy bubbles, your head gasket is probably all right. you should take off your valve cover to see what the oil on the cams looks like, though.
Jax2k
May 29, 2013 08:16 PM
s2k_CAL
Feb 27, 2010 05:44 AM
harrison1990
Feb 21, 2010 03:43 AM
ROTFLMAO
Jan 29, 2008 03:52 PM
sexycheto88
Apr 16, 2007 08:55 AM
