White smoke..for a bit
#21
I went back to the stock cat as I just put on a Mugen exhaust, I don't see the white smoke with the new setup. It seemed much more prevalent with the HFC (which is almost the same as a test pipe, and just as smelly )
Mine first started when I switched to the HFC, and it seems to have gone away once I have gone back to the stock cat.
#24
Received 1,562 Likes
This thread reminds me of the effects commonly seen when Seafoam is used. Lots of thick white smoke coming out of the exhaust. It appears Seafoam is not the culprit here but the mechanism may be. Some kind of buildup is combusting. Buildup of oil, hydrocarbon deposits coming loose, all could bring this about.
#26
It won't do it with a working OEM cat because it's a 3 stage and it's designed to control Hydro Carbon HC emissions, as well as Nitrates of Oxide NOx, and somewhat control carbon monoxide CO.
#27
