Why does my alignment change while driving?
Old Jul 7, 2003 | 06:21 AM
Gernby's Avatar
Former Sponsor
You may have your front and / or rear wheels toed out. Toe out makes the car darty, and will make it follow patterns in the road surface much more than if they are toed in. How long has it been since you had it aligned? Did you lower the car and not have it realigned?
Old Jul 7, 2003 | 07:55 AM
The Reverend's Avatar
Your rear tire pressures are uneven (or your tire wear is uneven).
Try this:
Accellerate. Does the car will pull one way? Now let off the gas. Does the car will pull the other way? This is what happens if your rear pressures are uneven. If your fronts are uneven, the car will just pull one way no matter what.
In the future, keep an eye on this - it's not good for your differential to have to spin the wheels at different speeds all the time (due to the difference in circumference).
Old Jul 7, 2003 | 08:15 AM
johnyboy32's Avatar
[QUOTE]Originally posted by matt_inva
[B]There is always the possibility that you road that you are on has ruts from heavy trucks.
Old Jul 7, 2003 | 11:19 AM
slick rick's Avatar
This very simple, guys.
The more camber a car has, the more it wants to "jump around" (jump, jump j/k) because it takes less resistance to turn the fron wheels. And that's because the contact patch is smaller, among a few other things.
davidc1
Oct 21, 2011 10:13 AM
NFR_AP2
Apr 24, 2011 01:01 PM
Andrew77
Apr 5, 2009 06:28 AM
TheBeanSoldier
May 4, 2007 04:56 AM
dbaman007
Apr 18, 2006 11:28 PM
